2005 accord v-6 coupe electrical issue
Old Feb 4, 2013 | 03:42 PM
kevin Taillon's Avatar
Default 2005 accord v-6 coupe electrical issue
Im driving down he highway with my cruise control on. I use the left directionl to move into another lane and the instrument cluster goes black and the car seems to shut off for a split second. The next time I use my turn signal this occurs again. Then it happens again when I apply the brake to take an offramp. The cluster just goes black and then comes back on all gauges go to zero and it clicks like when your battery is dead and you are trying to start the car. Then it all comes back on. It has happened when i use the turnsignals, the headlights and the brake. But not the radio, heater controls or seat heater. Any ideas?
I have visually checked the battery terminals and am getting ready to go clean and retighten them.
Old Feb 4, 2013 | 03:54 PM
There was a safety recall where the Fuse Box May Cause a No-Start or Stalling Condition.
Honda TSB 05-014
Old Feb 4, 2013 | 04:22 PM
The car doesn't stall in traditional sense more like it shuts off..
like in a split second all of this happens
Old Feb 4, 2013 | 04:25 PM
And then the dash lights back up and car" restarts"
The dealer said that it could be the ELD or the alternator is going bad or the ignition switch
Old Feb 5, 2013 | 06:00 PM
Did the dealer CONFIRM the safety recall was done? Even if that is not the cause of the issue, they should do the repair...safety recall - they must do it.
Be sure the ground cable is clean and tight....might not hurt to have the battery tested.....cold.
ndubg
Feb 26, 2014 10:11 PM
brahmabull
Jul 25, 2012 12:49 PM
Wylecyot
Apr 25, 2011 08:51 PM
Lateef
Aug 4, 2010 10:59 PM
Metro
Jan 13, 2009 02:53 PM
