2005 accord v6
Old May 31, 2015 | 08:20 PM
A.torres635's Avatar
Default 2005 accord v6
Hi honda folks I've been having a problem with my 05 v6 accord
when I take off easy the transmission shifts perfect but if I suddenly have to punch it it hesitates a bit then it let's go hard with a bang I feel like it's gonna brake the mounts which I just replaced I changed the oil with honda oil but still the same what can it be?
need help thx...
Old Jun 1, 2015 | 07:29 AM
Is check engine light On or D4 light flashing? If yes, then check for codes.
Shop manual suggests for hard shifts to check the D indicator (shift selection switch?) connectors for looseness, check AT clutch pressure solenoid valve filter/gasket for wear, damage, or seizure. Also check mainshaft speed sensor and countershaft speed sensors for correct function; damage or correct installation.
A shop manual is essential if you intend to DIY. Check automanualsource.com for an inexpensive ($22) download e-manual.
faran
Aug 1, 2016 06:07 PM
pedalfaster
Apr 19, 2007 03:01 AM
Rambo2810
Apr 11, 2005 03:27 AM
lcc27
Mar 8, 2005 02:49 AM
GolfingTiger
Mar 7, 2005 06:02 PM
