2005 accord wont start
Old Apr 4, 2015 | 07:08 AM
rmeeker's Avatar
here are the codes P0498 AND P0135
Old Apr 4, 2015 | 10:30 AM
DTC P0498: EVAP Canister Vent Shut Valve Circuit Low Voltage
DTC P0135: A/F Sensor (Sensor 1) Heater Circuit Malfunction
First check under-dash Fuse No. 4 (15A) and No. 23 (7.5A). Both these fuses are related to the A/F sensor relay (located in the under-dash fuse/relay box). The A/F sensor relay provides power to both the EVAP Canister Vent Shut Valve and the heater circuit of the A/F sensor.
If the fuses are good and power is at both sides of the fuses, you can swap the A/F sensor relay with the one of the relays right next to it (as they should be the same type) to see if things change. The A/F sensor relay is located in the under-dash fuse/relay box, at the bottom row with 4 relays, from left to right, it is the 3rd relay.
If no change, wiring may be checked next.
Old Apr 4, 2015 | 02:48 PM
Turtlehead's Avatar
okay guys heres what I did I found the ecm/pcm and unplugged every thing and then plugged them back in and now the car starts and runs like it did the only thing now is the check engine light wont go off we tried to reset it but it wont go away but hey the car is running
Always get the code(s) before attempting to reset. If you go some place to have it read write down the code numbers and don't rely on what they give you for the description. Glad to hear it is running. It may have been a poor intact at the ECM but there may very well be another issue that you can resolve.
Old Apr 4, 2015 | 08:33 PM
rmeeker's Avatar
i will try and post the codes on sunday or Monday
Old Apr 5, 2015 | 07:27 PM
rmeeker's Avatar
the codes are po135 and p0148
Old Apr 5, 2015 | 07:31 PM
rmeeker's Avatar
thanks redbull-1 I will check that out and let you know what I find out thanks for all your help it sure is nice to have a place to get good help
Old Apr 5, 2015 | 08:07 PM
  #17
Is P0148 correct? It is not listed in my shop manual.
Old Apr 8, 2015 | 06:31 AM
  #18
rmeeker's Avatar
yes it is i have cleared all codes now i had a bad fuse not letting me clear codes thanks for all your help guys thanks
Old Apr 8, 2015 | 08:47 AM
  #19
Thanks for reporting back the issues are resolved.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
smoletx
Feb 20, 2008 10:13 AM
MrGmo
Sep 28, 2007 01:40 AM
