2005 Honda Accord ex 5 speed high idle
Old May 21, 2021 | 12:18 PM
Accord376's Avatar
Default 2005 Honda Accord ex 5 speed high idle
Recently just bought this car and what I’ve noticed whenever I start it up the car immediately revs to 2k-3k rpm just recently changed the tps sensor, it cleared engine codes and no check engine light is on the car what else what would be causing this issue?
Old May 21, 2021 | 08:19 PM
It could be many things, but I'd check for a vacuum leak as one of the likely candidates.
Old May 21, 2021 | 11:39 PM
What this happening before the repair? Is it possible that you did not get the new TPS sensor installed properly? I think the TPS and throttle body (or APP sensor) are keyed so you get the sensor installed correctly, but you may be able to install it off by a large degree.
randyjose
Aug 12, 2023 01:34 PM
Daz
Jun 12, 2017 11:57 AM
Troy Lauzon
Jul 16, 2013 01:12 PM
MrFalsetto Butler
Aug 18, 2012 10:19 AM
bangbang615
May 30, 2011 09:22 AM
