Sponsored by:
Sponsored by:
1999 Honda Accord radiator issue, please help
Old 09-06-2018, 10:41 PM
Erin321's Avatar
Default 1999 Honda Accord radiator issue, please help
hello all, I have a 1999 Honda Accord it seems to be leaking radiator fluid about a foot in from driver’s tire. I can not seem to find anything about this area on the vehicle. It is half
way down engine block.
Old 09-08-2018, 11:32 AM
75Gremlin's Avatar
hard to tell anything from your photo. Are you sure one of the radiator/coolant hoses isn't leaking?
Old 09-08-2018, 12:29 PM
Erin321's Avatar
I’ve looked at all the hoses they seem to be fine, that small hole at the back of engine almost parallel to bottom of steering wheel, ugh lol it becoming more trouble than it’s worth I think. Thank you all for helping I’m gonna try n work on it again and see what’s going on 😩
Old 09-08-2018, 12:35 PM
75Gremlin's Avatar
In my experience, most of the time these radiators fail where the plastic and metal meet. They usually start leaking slowly, and progressively get worse. Sometimes you can see dried antifreeze where the plastic/metal meets. Check those areas carefully.
Old 09-08-2018, 12:36 PM
Erin321's Avatar
Ok I will go over with fine tooth comb, thank you very much for helping. If all else fails I may just clog hole with bubble gum lol
Old 09-08-2018, 12:58 PM
Seanjordan20's Avatar
Do you have a 4cyl or 6cyl. Have you checked the hoses in the rear of the engine by squeezing them
Old 09-08-2018, 01:55 PM
The Toecutter's Avatar
Are you sure it's not leaking out the water pump weep hole? If you have the 2.3L 4 cylinder, that's where I'd start looking.
justonestep
09-24-2021 08:34 PM
emilyrl2012
07-11-2014 09:52 PM
Novaknowledgenow
05-30-2013 08:58 PM
hmr
03-28-2012 10:49 PM
art vandelay
08-02-2010 09:29 AM
Quick Reply: 1999 Honda Accord radiator issue, please help
