2005 Honda Accord weird brake light issue
Old Jul 26, 2013 | 08:52 PM
misterdeez's Avatar
Default 2005 Honda Accord weird brake light issue
Hello,
I'm not great with cars but I am good with electrical stuff. I seem to be struggling with a weird brake light issue on my 2005 Honda Accord LX.
Stupid question first but these are the brake lights in red, correct (not my car)?
http://carphotos.cardomain.com/ride_...4019_large.jpg
It appears my 3rd center brake light works correctly but the two side ones don't. They are always off when the headlights are off and always on when the headlights are on, pressing the brake does nothing. All the other lights work fine.
I checked the fuses and then checked the brake switch, it appears to be working correctly but I could be wrong. There are four wires red, white/black, green, and brown. The red and white/black short together when the brake is pressed, the green and brown are short when the brake is not pressed, but open when the brake is pressed. Is this how the switch is supposed to behave?
Is there another explanation for my brake light problem?
Thanks!
Old Jul 27, 2013 | 07:44 AM
Yes the switch testing is correct.
Please check the bulbs - they are dual element. One could be burned out.
Next, check for voltage on the WHT/BLK wire of the bulb socket when the brake pedal is pressed.
Old Jul 27, 2013 | 08:21 AM
It's strange and surprising, but I could not find a circuit diagram for brake lights in my 2003-2007 Accord Shop Manual. Describes replacing LED's and checking brake pedal switch, but no wiring diagram! It's a large manual and may be there but out-of-place, but I dont' think so.
Problem suggests perhaps a ground path problem. Suggests checking grounds in the trunk carefully.
Old Jul 27, 2013 | 09:21 AM
In the service manual, it should be under Body Electrical, Exterior Lights, Circuit Diagram, Circuit Diagram - Brake Lights. Page 22-184.
Old Jul 27, 2013 | 09:32 AM
Thanks RB, I paged over somehow.
regard
Old Jul 27, 2013 | 09:38 AM
After viewing wiring diagrams and reviewing your post, the problem suggests a wiring damage, perhaps from someone wiring trailer lights. Do you have a bumper hitch?
In any case, you will need to investigate the wires in the trunk to locate damage/cross-connection.
MrAdams21
Jun 28, 2013 08:08 PM
hcker2000
May 25, 2013 09:40 AM
MDawg
Feb 9, 2012 05:17 PM
victorywhity
Mar 24, 2011 09:37 PM
sweeks
Dec 20, 2007 10:24 AM
