2005 Honda Factory tires
Old Jul 17, 2010 | 02:44 PM
DanTN's Avatar
Default 2005 Honda Factory tires
Greetings Accord Lovers,
I recently purchased a 2005 Honda Accord LX 2.4L Automatic. The car has been garage kept, it appears and drives as new. The only change I would like to make is to get rid of those factory steel wheels/covers and replace them with an option in 2005, the 7 spoke aluminum alloy painted silver with clearcoat. I have found and ordered the wheels, caps and lugs. I would like to keep the car all original and would like to know what kind of tires (make/model/size) were on this optional 7 spoke wheel supplied by Honda in 2005. Any help would be much appreciated, I have searched to no avail.
Thank you, Dan
Old Jul 17, 2010 | 10:48 PM
hondadude's Avatar
So you are asking for tire size of an EX model 2005 accord?
If it is the same rim diameter I'd bet it's the same dimension tire
Old Jul 18, 2010 | 05:16 AM
DanTN's Avatar
Default I am looking for the OEM tires
I am looking for the actual tires that were supplied by Honda on the 16 x 6.5 - 7 spoke aluminum alloy wheel in 2005. Brand, type and size.
Thanks, Dan
Old Jul 18, 2010 | 04:01 PM
kris_loehr's Avatar
You can order your tires from Majestic Honda just look up WHEEL DISK after putting in the Accord model which came with the wheels your are using. The size is listed but not the brand. I looked up a 2005 Accord EX coupe and the tires were around a hundred dollars.
Old Jul 18, 2010 | 04:25 PM
DanTN's Avatar
Default Thank You Chris.
Thank You Chris. Did anyone out there get these 16 x 6.5, 7 spoke aluminum alloys on their 2003-2005 Accord Sedan? If so, what brand and model tires came from the factory on the vehicle? A photo of the wheels that are on the way follows. Bright Sparkle Silver Full Face painted factory OEM aluminum alloy wheels, rims with clearcoat.
Thanks, Dan
Old Jul 18, 2010 | 05:19 PM
DanTN's Avatar
Thank you guys, I found my answer somewhere else on this forum!
Regards, Dan
KenA
Jan 25, 2013 06:44 AM
bblessent05accord
Feb 2, 2012 02:09 AM
jblaust
Jul 6, 2008 11:31 PM
jblaust
May 3, 2008 04:37 AM
maro
Mar 10, 2007 12:15 AM
