2005 lx 4cyl
Old Dec 18, 2010 | 07:53 PM
monsterb1's Avatar
Default 2005 lx 4cyl
need help on valve adjustment, need to find out where to buy exact size feeler gauges ( .22mm int and .30mm exh) thanks
Old Dec 18, 2010 | 07:54 PM
monsterb1's Avatar
Default 7 gen engine block heater
anybody needs help with engine block heater install?
Old Dec 18, 2010 | 08:03 PM
monsterb1's Avatar
I just did my valve adjustment at 92k. nothing really needed to be done except spark plug replacement. Stupid me i i adjusted the 1st cylinder without checking if it needed adjustment. Reason why i did it was because during cold start the engine was cla cla cla cla a lot and when it wormed up it was fine. Well now that i adjuster the 1st cyl it cla cla cla all the time. Is it because i used .305 mm and not .300 for my exhoust side ? Thanks
Old Dec 19, 2010 | 09:09 PM
Seems like that's a very tiny difference (0.305mm=0.012" & 0.300mm=0.0118")
I don't know the allowable range but maybe 0.30mm is the large end of the range. Try the next smaller feeler gauge.
Did you measure when the engine was cold?
Old Dec 30, 2010 | 10:12 PM
bassic's Avatar
Is there a tech writeup on the adjustment procedures? I found a thread from 07 that referenced a writeup in the DIY section, however those threads seem to have been moved to the general tech section, and I can't find what I need.
I have an 03 2.4 with 125K and there's a single valve that's very noisy. It sounds like a Honda, but if I can adjust it and make it go away, I'll be happy.
kenwood guy
Sep 15, 2013 03:02 PM
virep1
Aug 28, 2011 03:49 AM
honda1234
Aug 28, 2009 12:53 PM
prodrive
Oct 1, 2008 04:01 PM
smoletx
Feb 20, 2008 10:13 AM
