Sponsored by:
Sponsored by:
2005 lx 4cyl
Old 12-18-2010, 07:53 PM
monsterb1's Avatar
Default 2005 lx 4cyl
need help on valve adjustment, need to find out where to buy exact size feeler gauges ( .22mm int and .30mm exh) thanks
Old 12-18-2010, 07:54 PM
monsterb1's Avatar
Default 7 gen engine block heater
anybody needs help with engine block heater install?
Old 12-18-2010, 08:03 PM
monsterb1's Avatar
I just did my valve adjustment at 92k. nothing really needed to be done except spark plug replacement. Stupid me i i adjusted the 1st cylinder without checking if it needed adjustment. Reason why i did it was because during cold start the engine was cla cla cla cla a lot and when it wormed up it was fine. Well now that i adjuster the 1st cyl it cla cla cla all the time. Is it because i used .305 mm and not .300 for my exhoust side ? Thanks
Old 12-19-2010, 09:09 PM
Seems like that's a very tiny difference (0.305mm=0.012" & 0.300mm=0.0118")
I don't know the allowable range but maybe 0.30mm is the large end of the range. Try the next smaller feeler gauge.
Did you measure when the engine was cold?
Old 12-30-2010, 10:12 PM
Is there a tech writeup on the adjustment procedures? I found a thread from 07 that referenced a writeup in the DIY section, however those threads seem to have been moved to the general tech section, and I can't find what I need.
I have an 03 2.4 with 125K and there's a single valve that's very noisy. It sounds like a Honda, but if I can adjust it and make it go away, I'll be happy.
kenwood guy
09-15-2013 03:02 PM
virep1
08-28-2011 03:49 AM
honda1234
08-28-2009 12:53 PM
prodrive
10-01-2008 04:01 PM
smoletx
02-20-2008 10:13 AM
Quick Reply: 2005 lx 4cyl
