2006 Accord EX Turn Signal/4 way problem
Old Jun 6, 2015 | 08:15 PM
rogstar69's Avatar
Default 2006 Accord EX Turn Signal/4 way problem
Any help would be appreciated. My 4way/emergency flashers stopped working and my turn signals work only intermittintly.They work for a few minutes then not at all for a while. There is a loud buzzing when I pull down the lever. Thanks for your attention.
Old Jun 6, 2015 | 10:40 PM
Since you are having issues with both hazards and the turn signals, I would suspect an issue with the hazard switch or the turn signal/hazard relay. I am out of town for work, so I can't access the wiring diagram.
You will have to do some electrical testing using a volt meter. I'd probably test at the hazard switch first. I'd suggest getting a pdf of the shop manual if you plan on DIY work. It is an invaluable resource. You can get one for your car for ~$22 at automanualsource.com. It is worth every penny.
Old Jun 8, 2015 | 09:25 AM
rogstar69's Avatar
Thanks for the ideas/help!
PeterFlorida
Feb 26, 2013 09:09 AM
nva_2007
Aug 20, 2009 12:25 AM
rtsulliv4801
Feb 4, 2009 05:33 PM
Digiti
Aug 4, 2007 09:28 AM
hawkeye
Jul 10, 2007 04:13 PM
