2006 Accord EX V6 Brake Lights Off then On
Old Oct 18, 2011 | 08:47 AM
tgudex19's Avatar
Default 2006 Accord EX V6 Brake Lights Off then On
Hi,
I have just noticed that my brake lights come on when the pedal is pressed then do not come on the next time the pedal is pressed. The brake lights sometimes come on then go off when the pedal is pressed continuously. I do not believe it is a blown fuse because the brake lights would not come on at all. I also don't believe it is a broken switch, again becuase the brake lights would not come on at all. I am not car savy so maybe could be either of these two issues. Any ideas?
Thanks,
Tim
Old Oct 18, 2011 | 11:15 AM
deserthonda's Avatar
could be a poor connection and a brake switch acting up intermittently
need to test power and ground at brake switch + make sure that wiring at switch is ok not a loose connection
Old Oct 18, 2011 | 11:25 AM
tgudex19's Avatar
Thanks. Can you describe how I would test this w/o electrocuting myself and the tools I would need, or direct me to a previous thread. Do you think the problem is around the pedal/switch, or could it be any where along the wiring?
Thanks,
Tim
Old Oct 18, 2011 | 05:41 PM
A volt meter helps....a test light might work.
Also, does the brake lamp warning (car icon) come on at any point?
I've also seen a "sticky" switch before-meaning the "plunger" on the switch does not come out (turning on the brake lights)....some have removed the switch and "clean/lubed" it and corrected the issue.
ughcord
Mar 9, 2019 05:19 AM
baldjbb
May 31, 2011 03:46 PM
SolEX01
Aug 10, 2010 05:04 PM
danielwebb
Apr 5, 2010 08:58 AM
joewittbro
Sep 28, 2009 11:36 PM
