2006 Accord Se 4 Cylinder rotor removal
Old Jan 27, 2009 | 05:52 PM
06HAccord
Default 2006 Accord Se 4 Cylinder rotor removal
I am in the process of installing new brakes on my 2006 Honda Accord. I never did brakes on a Honda Accord. I wanted to know what was involved with replacing the frontand rearrotors.After removing the calipers do they slide off of the hubor does the knuckle need to be removed. Thanks Anthony
Old Jan 27, 2009 | 08:57 PM
Default RE: 2006 Accord Se 4 Cylinder rotor removal
The rotors are over the hub so the should slide off. There might be two screws holding the rotor to the hub.
A Haynes manual would be a good investment (~$20) that has details on maintenance items.
Old Jan 28, 2009 | 06:24 AM
After the caliper is off, theres one flat-head screw. Use an impact screwdriver, the kind you hit with a hammer.
Then it may be stuck with rust, so spray some PB Blaster. It separates from the hub just outside the projection that engages the center-hole in the wheel.
CYB3R
Dec 23, 2014 12:15 AM
mieklein
Jan 9, 2014 06:38 AM
Chris Jameson
Feb 19, 2013 06:39 AM
respectmyfresh
Mar 31, 2009 01:51 PM
rmistry7
Dec 20, 2006 10:21 AM
