2006 Accord V6 Rough Idle Issue
I have a 2006 Accord V6 with 126K Miles. I'm experiencing a rough idle at stop and the check engine light is on. I had the car scanned for codes, and three came up.
1. P0304 - Cylinder 4 Misfire Detected
2. 65-1 - Brake Fluid Low Level
3. 61-1 - Battery Voltage Malfunction
All 6 spark plugs were replaced at 74K miles. How would I know if it's the plug for Cylinder 4 or the coil? Could it be valves? I do hear a ticking noise. I added more brake fluid, and the same code appears. I also had them check the battery and charging system and all seems to be ok.
Do you know could be the problem?
Thanks
Thanks
I'll try that, thanks. However, last night I unplugged the wire to cylinder 4 coil and notice the engine shakes slightly. I then unplugged another cylinder coil and the engine shakes much more. Could this be that i have a bad coil or a bad spark plug?
I prefer to do a full tune up though. Cap, rotor, plugs and wires. The owner's manual calls this out. I do this espescially if I dont know when it was last done.
I'll get the NGK laser Iridium's. Also, this is a 2006 Accord V6, no cap and rotor. It has coil packs for each cylinder. Should i replace all the coil packs when replacing the spark plugs? If so, should i go dealer or aftermarket on the coil packs?
Thank you.
Thank you.
Generally don't replace the coils "just because". When you replace the plugs, look at them for any visible problems.
I think if new plugs don't fix it, then look at the coils. If the misfire follows the coil to a new cylinder, then replace that one.
Exhaust valves on the 3.5V6 can tighten w/ mileage due to wear. If over 100K miles, you are due for a valve adjustment. A too-tight exhaust valve can cause missing and lead to valve damage if not addressed.
First make sure it's not a Coil-Over-Plug (COP) or fuel injector.
#4 is the pax side cylinder on front engine bank.
Aftermarket COP'
Aftermarket COP'
