2006 Honda Accord help!
Old Jan 31, 2011 | 08:57 AM
TonyR's Avatar
Default 2006 Honda Accord help!
I have a 06 Accord 4 dr.... Recently I noticed the left front turn signal works intermittently. When it does not work, the frt bulb will not blink, rear does real fast, and indicator on the dash also flashes fast. Some days it works fine and others it does not. I am thinking it is the switch on the column... Any thoughts would be greatly appreciated. Thanks in advance.
Old Jan 31, 2011 | 11:47 AM
Sounds like the flasher relay located in the driver side under dash fuse/relay box.
Old Jan 31, 2011 | 11:58 AM
I'd look for intermittent loose connection at the front.
The rapid flashing indicates a burned-out bulb, which is just what it would do if the front bulb were disconnected.
Old Jan 31, 2011 | 12:02 PM
+1..... I also agree, look for burn-out bulb.
Old Jul 18, 2012 | 11:38 AM
Ramonaroy's Avatar
I too have a Honda Accord 2006 4dr, however my left signal does not come on at all, no blinking/no clicking and does not come on when the hazzard button has been pushed. My right signal is fine. Would this too be a flasher relay issue?
Old Jul 18, 2012 | 12:34 PM
Silver6gen's Avatar
more than likely yes.
zepljak18
Nov 2, 2013 12:19 PM
COWBOYSfan96734
Oct 13, 2013 12:11 AM
mamtsberg
Mar 17, 2010 09:15 PM
mangups
May 31, 2009 02:20 PM
cellstop2
Jul 22, 2006 11:23 AM
