2006 honda accord v6 3.0l engine revs but no power to wheels, car wont move
so my 06 accord died on me yesterday (168k miles roughly). i was driving on the highway, went to switch lanes to pass someone, and the engine revved up high but i was losing speed. i pulled off to the side of the highway, and the car wouldnt move. i tried all gears, the normal drive as well as lower gears, and reverse. when i switch gears, the parking gear does disable, as the car will start to roll forward as if the brakes are disengaged. the fluid level for the transmission is good, the fluid is clean and full. i tried turning the car off and letting it cool down a bit. the car starts with no issue, and when i press the gas i am still getting rpms, just no actual power to the wheels. yesterday there were no CEL codes coming up, no lights on the dash. this morning i went out to check again, and now i have a CEL on, code is U0155 "Lost communication with IPC". anyone know whats going on here? the transmission has been serviced every 60k miles (ive had the car since 61k, and that was the first thing i did). there were no early signs of failure or anything, the only warning i got was the day before, the car did the same thing to me on the highway, but it caught again and let me drive it after a second or 2.
U0155 is a code for the network communication on your car where the control modules talk to each other. The CAN is the controller area network. In your case the issue is on the fast CAN or F-CAN network. This issue can be any control module on that network.
A scanner that can read some live data will help, where you can try reading signals from the VSA, ABS, PCM, gauge cluster to see if one of the items is not reporting proper data. I suspect a component is failed on the network and now there is a break in the communication line. What kind of scanner do you have?
