2006 Honda Accord won't start?
Old Jun 18, 2012 | 04:30 PM
wee8519's Avatar
Default 2006 Honda Accord won't start?
Everything turns on but the car wont turn over or start. Battery is good, can it be the starter or the solenoid relay? Is anyone having these problem that can some help on what I should do or what I should check/replace?
Old Jun 18, 2012 | 05:59 PM
This really belongs here.
Have a volt meter or test light? If so, see if you are getting voltage to the small wire at the starter (and how much if you have a volt meter) whne someone is turning the key to "start".
Old Jun 18, 2012 | 06:06 PM
Is this a 4 or 6 cylinder? The starters on the 4 cylinders were a relatively common problem. If it is the starter on the 4 cylinder, it is under the intake manifold.
Old Jun 18, 2012 | 10:48 PM
Dr. Drivability's Avatar
if it is the 4 cylinder, take a long ratchet extension or long screw driver and stick it down through the intake manifold runners and tap the starter while someone is trying to crank it...if it turns over...
Tony1M
Nov 6, 2023 08:29 PM
Sheri6889
Jun 17, 2015 08:19 AM
lopez1251
Jun 22, 2011 04:50 PM
hownerx3
Oct 26, 2009 06:10 PM
