95 accord intermittent starting problem
Old Jun 18, 2012 | 10:33 PM
Life is an Odyssey's Avatar
Default 95 accord intermittent starting problem
Problem #2 with my accord. I have an intermittent starting problem. I can go a week or more with no problem and then it won't start. No sound just won't turn starter.Then after turning key lots of times it will start. (manual trans) I checked the ground, it's good. I replaced the starter. Didn't solve the problem. Any ideas? Thanks.
Old Jun 18, 2012 | 10:53 PM
When you turn the key to start the car, the battery power goes through the electrical part of the ignition switch, through the clutch switch, and to the starter. That is for the small blk/wht wire going to the starter.
The positive cable from the battery supplies the power to turn the starter motor.
I would probably try to verify that you are getting 12V to the small blk/wht wire going to the starter. Since this is intermittent, I would wire a 12V test light on the post for the blk/wht wire and secure it with the eyelet and bolt. I would run the wire to under the windshield and tape that light to where you can see it. Ground the other end of the test light to any bare metal bolt. There is one bolt on the drivers side of the engine next to the valve cover.
Then you can look at the light to see if you have 12V when it is starting properly and verify that you are not getting 12V to the starter when it is not starting.
junkmaneast
Dec 2, 2018 04:29 PM
mattcadieux1
May 8, 2013 08:45 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
clarity
Dec 26, 2007 06:19 AM
cyurgeles
Jan 21, 2006 10:36 AM
