2007 Accord 4 Cyl - How-to change tranny fluid
Old Mar 25, 2012 | 03:10 PM
tobybul's Avatar
Default 2007 Accord 4 Cyl - How-to change tranny fluid
Is changing the tranny fluid on a 2007 Accord 4 Cyl the same as a 2007 V6 Accord? I plan to change my kid's 4 cyl and I've only done it on my v6. The v6 has a 17mm oil fill bolt above the tranny where it can be filled. Does the 4 cyl have the same bolt? or is it just filled thru the dipstick? And is the drain plug just a 3/8 rachet?
Thanks.
Old Mar 25, 2012 | 04:29 PM
EXV6NIGHTHAWK's Avatar
I think you have to use the dipstick to fill, and the filter is in-line, instead of internal. That's the only differences I know of. The capacity is probably different too, don't know.
Old Mar 25, 2012 | 04:55 PM
hondatech516's Avatar
the drain plug for the trans is the 3/8 that u have said, to fill, use the dipstick hole.. 3 quarts will fill it.. also use only honda atf z1 or the updated fluid. (dwb 1 i think).. good luck
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
logannz
Mar 30, 2013 05:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
