2007 accord a/c only works on passenger side
Old Aug 16, 2016 | 06:31 AM
c2m8c's Avatar
Default 2007 accord a/c only works on passenger side
with the a/c on cold air blows on the passenger side and hot air blows on the drivers side. what in the world causes this?
thanks
Curtis
Old Aug 16, 2016 | 07:05 AM
If you have dual controls the drivers side blend motor may have failed. If you hear grinding/popping sounds from near center of dash, this problem is likely. Door motor is easy to replace on most systems.
Also low charge level on the AC system can cause this problem. Evap become stratified; warm on top and cold down low.
southbronxyank
Jul 26, 2014 10:49 AM
drugrep
Jun 3, 2013 09:32 AM
Getitright
Jun 7, 2012 09:08 AM
bigbadbuff
Apr 17, 2012 12:56 PM
