2007 Accord Ignition Buzz
Old Oct 22, 2010 | 01:14 PM
Worstboatever's Avatar
Default 2007 Accord Ignition Buzz
I have a 07 accord when I start the car the turn signal hazard relay makes a buzzing noise. I replaced and checked all grounds It still buzzs.....Please help! do you think maybe i missed a ground or am i way off base??
Old Oct 22, 2010 | 01:16 PM
you can email answers if you want.
Just use the email function on your profile. Posting you email address can attract spammers. -PaHonda
I`am lost
Old Oct 22, 2010 | 01:35 PM
That relay makes a buzzing noise, even if you don't turn on the turn signals/hazard switch?
Just to be sure you found the correct relay, unplug the relay and make sure the noise goes away.
Old Oct 22, 2010 | 03:15 PM
Default relay
the noise goes away when i unplug the turn signal relay no buzzing
Old Oct 22, 2010 | 03:18 PM
Have you checked out the parts stores yet for a price on a switch.?
Default relay
signals work fine and hazzard lights no buzzing only when i start the car take out relay no more buzz???
Old Oct 22, 2010 | 03:20 PM
Default relay
I already wasted 21.00 dollars on a new switch its not the switch
Old Oct 22, 2010 | 03:28 PM
Default relay
every thing works fine except for when i start the car,then the turn signal relay buzzes......if i take out the relay turn signals dont work or hazzards....but when i start the car with the relay out theres no more buzzing..in other words when i start my car my turn signal relay buzzes and i replaced the relay and it still buzzes
Old Oct 22, 2010 | 03:40 PM
Which switch did you replace?
