2007 Accord Ignition Buzz
Old Oct 23, 2010 | 08:35 AM
  #21
EXV6NIGHTHAWK's Avatar
The multiplex is the computer part of the under dash fuse box. Two parts in one.
Old Oct 24, 2010 | 12:02 AM
  #22
Worstboatever's Avatar
Default relay
only buzzzing when key is turned switch have no effect
Old Oct 24, 2010 | 01:15 PM
  #23
Default help
Well that was a waste of time.I guess no help here.
Old Oct 24, 2010 | 02:48 PM
  #24
|Dont blow a gasket..there's help in here about most anything.Maybe no one has had that incident yet and really don't know..
Old Oct 24, 2010 | 03:53 PM
  #25
Can you explain this better? Its hard to give suggestions when it isn't clear what you have tested.
Old Oct 25, 2010 | 02:39 AM
  #26
I tested the switches you told me to test...........theyre fine once more turn signal hazard relay is good too only problem is it buzzes when you turn the ignition
ripped apart the dash and took off the steering wheel
Old Oct 26, 2010 | 02:02 AM
  #27
Default turn signal relay
If you can`t remember what you told me to test,why don`t you admit you haven`t a clue why it`s buzzing.I only explained it 5 times.How can we get anywhere when you can`t remember what you told me to test are you slow?ADD... maybe.. if so then I apologize....
Old Oct 26, 2010 | 03:03 AM
  #28
Insults to me or any other member of this forum will not be tolerated. Period.
I really do not know why the relay is buzzing, and I am trying to give you some ideas to try. I think it is obvious that some input to the relay is the problem. The two switches are inputs, so that is why I asked you to unplug them.
The problem is that I do not have a wiring diagram for a newer accord to tell you to test pin x, y, and z for voltage or ground.
"only buzzzing when key is turned switch have no effect" That was your reply. I asked you to explain, because that sentence is not clear to me.
I am guessing that you unplugged the turn signal and hazard switches and you still have the buzzing sound. Is that correct. I do not like to assume anything. Some minor point could be missed and make things more confusing.
Old Oct 27, 2010 | 01:36 AM
  #29
Question Question For You
And when are you leaving for Anger Management School..
Old Oct 27, 2010 | 03:47 AM
  #30
Default relay
that is correct tested turn signal and hazard switch tested ok relay only buzzes when key is turned...............what else possibily would be another input???reverse lights maybe??
