2007 honda accord electric problems
Old Apr 16, 2015 | 03:29 PM
thisguy80's Avatar
Default 2007 honda accord electric problems
Yesterday i connected the battery the wrong way i blew the battery fuse replaced it car seemd fine turned on and everything turned off the car but the starter stayed on and wouldn't turn off had to disconnect the positive terminal so it could turn off any advice on what it could be i know its an electric problem cause removed the starter took it to get tested and works fine?
Old Apr 16, 2015 | 06:51 PM
If you connect the cables back up, does the starter run? Or only if you try to start the car with the starter does the starter stay running? Just trying to get details to try to help.
Also, can you give the trim/engine/trans of the car as if we have to get into wire details this will help.
PS - Thanks for joining HAF
Old Apr 17, 2015 | 03:43 PM
thisguy80's Avatar
Appreciate. Tha advice but it works fine know
kkjohns123
Sep 1, 2013 05:13 AM
nickvilardi
Aug 15, 2011 12:18 AM
whipsey
Dec 18, 2010 06:40 PM
LambertJohn
Sep 17, 2010 01:47 PM
