2007 SE V6 Blinking instrument panel
Old Jul 28, 2012 | 05:07 PM
mhr's Avatar
mhr
Default 2007 SE V6 Blinking instrument panel
Hi-
I just finished replacing the downstream O2 sensor closet to the firewall (Bank 1 sensor 2) to clear a "check engine" code. It took me a week to get the part (long story) and I used a Denso 234-4368.
I go everything back together with no issues. When I turned the key, the instrument panel started blinking! The "check engine" light is off (moral victory!). But the "brake" light is now on permanently, as are the "Airbag" and "VSA" lights. I did a quick check inside the engine compartment and couldn't find anything that was unplugged.
Any ideas would be greatly appreciated!
Old Jul 28, 2012 | 05:53 PM
mhr's Avatar
mhr
Update: the "ABS" (not the "airbag") light is on and none of the instruments function when I drive: speedometer, tach, fuel, temperature.
Old Jul 29, 2012 | 07:22 AM
Check the fuses first. Sounds like one or two have blown.
Old Jul 29, 2012 | 06:39 PM
mhr's Avatar
mhr
Default fixed
Hey Poorman212-
I pulled every damn fuse. They were all good! But, fearing further trouble from my
incompetence, I disconnected the battery before starting the excercise. When I finished sampling the fuses, I reconnected the battery and all the problems went away! I guess the computer just needed to be reset?
Anyway, thanks for helping me solve the problem and avoiding the dealership jackals!
Old Jul 30, 2012 | 06:21 PM
Hey, glad it was a simple fix???? Thanks for the update
VBALVERDY
Nov 10, 2011 10:41 PM
double shot
Oct 29, 2010 10:24 PM
RedCruiser
Nov 27, 2006 11:24 PM
ButtonMan
Jul 4, 2006 11:51 AM
