2008 Accord - Can't find radio fuse
Old Aug 30, 2012 | 01:44 PM
KayakingAccord's Avatar
Default 2008 Accord - Can't find radio fuse
I recently jump started my car with the radio on, not the smartest move I know, but neither was leaving the map light on for 2 days.
So now I have no radio, its a 2008 Accord Coupe V6 without Nav but with premium radio. I am waiting for a call back from the dealer but am trying to solve this issue in the meantime.
What are the chances my radio is fried? ANd where is the fuse that controls it?
I appreciate all your help in advance
Old Aug 30, 2012 | 02:36 PM
Is it only the radio?
Check the No. 15 (10A) fuse located in the under hood fuse box.
Usually the fuse blows first.
Attached Thumbnails 2008 Accord - Can't find radio fuse-underhood-fuse-box.jpg
Old Aug 30, 2012 | 05:08 PM
Seems to be only the radio, I am going to start it and test everything out in a bit. I ended up needing a battery so had to get that done.
That 10A fuse is ok
Old Aug 30, 2012 | 05:40 PM
In the circuit is the No. 3-8 (50A) fuse that is part of the combined fuse. See attached pic. on how to check.
Also, for your V6, take a look at No. 19 (7.5A).
Attached Thumbnails 2008 Accord - Can't find radio fuse-under-hood-fuse-box.jpg   2008 Accord - Can't find radio fuse-checking-combined-fuse-box.jpg   2008 Accord - Can't find radio fuse-combined-fuse-box.jpg
Old Aug 30, 2012 | 05:41 PM
After calling 3 dealerships and pulling half the fuses to check them, I charged the battery and now everything works!
Old Aug 30, 2012 | 05:50 PM
Glad to hear that it was only the battery.
Old Aug 31, 2012 | 11:19 AM
I was trying to check that fuse but could not figure out how to remove it....
Old Aug 31, 2012 | 11:25 AM
To remove the combined fuse (aka multi block fuse), the one bolt is removed, then it is pulled out. It is a little tough to pull out though.
Old Mar 9, 2013 | 06:31 PM
cjohnson831's Avatar
I tried the information listed below and all the fuses are fine. Still no sound coming out of speakers, yet the radio display comes on as if the radio is working properly. Any other suggestions.
Old Mar 10, 2013 | 08:06 AM
Is your car the same year? Also can we assume this is a stock/factory set up?
