2008 accord tail lights are out
Old Dec 14, 2011 | 07:03 PM
kevin.neisler's Avatar
Default 2008 accord tail lights are out
I have a 08 accord and the tail lights have quit working. I have changed the bulb and the brake lights work fine. I was wondering what to do next!
Old Dec 14, 2011 | 07:05 PM
I have a 2008 accord and the tail lights are not working. I have changed the bulb and still no luck. What should I do next?
Old Dec 14, 2011 | 08:28 PM
accordhybridowner's Avatar
Your car probably has a blown fuse. Check your manual for instructions on replacing fuses. The fuses are usually under the dashboard, but I'm not sure exactly where on the 8th gen Accord.
Here's a demo video:
How to Find Replace and know if you have a blown fuse in your car or truck - YouTube
Old Dec 14, 2011 | 10:58 PM
For a bulb not to work you are either missing voltage or ground to the bulb. You also need to be sure the bulb is good.
The first item I would check is the fuse for the tail lights. Look in the owner's manual for the location of that fuse.
Race4Honda
Aug 2, 2014 01:53 AM
myfirstisanaccord
Apr 24, 2011 08:25 PM
Paul79UF
DIY Answers.
Sep 11, 2010 11:15 AM
Vettress
Jul 7, 2010 11:10 AM
Will.bartlett
Feb 27, 2010 08:44 PM
