2008 Honda Accord Coupe LX (A/C issue?)
Old Jun 18, 2015 | 10:18 AM
Mdubs's Avatar
Default 2008 Honda Accord Coupe LX (A/C issue?)
I own a 2008 Honda Accord Coupe LX. I believe I'm having an issue with the A/C system. When the A/C is in the off position, something is still running in the background, like it sounds like its on the low setting. Additionally, the battery has died the last two days since the noise began. I got a hot shot yesterday and the car was running, but this morning when I tried to start it the battery was completely dead. Is something draining the battery, the battery is about 18-24 months old. I've read online that the AC relay could possibly be causing the battery drainage. Any advice would be greatly appreciated.
Old Jun 18, 2015 | 12:05 PM
AC compressor clutch relay (underhood fuse box) is always hot, so if contacts stick closed the compressor clutch will close (compressor should be turning w/ engine on).
If clutch is closed, try pulling the compressor relay. If that opens the ac clutch, a new relay should fix the problem.
illtl
Sep 3, 2009 06:38 PM
ajitdayal
May 11, 2009 08:07 AM
vuanhquoc21
Nov 24, 2008 12:02 AM
calexico888
Apr 20, 2008 04:17 PM
garrickhuie
Feb 16, 2008 11:22 AM
