2008 Honda Accord ex 2.4 at loud growl noise
Old Jan 2, 2023 | 01:27 PM
Leemanufacture's Avatar
Default 2008 Honda Accord ex 2.4 at loud growl noise
The growl noise has gradually gotten louder , seems to be coming form front passenger tire, gets louder with more speed , no change when shift to neutral, at first it would disappear when wheel was turned to the right but has since changed to becoming even louder when wheel turned to right, I have lifted car on jack stands and unable to find any play or movement in all 4 tires also no noise when spinning tires by hand, everything is as tight and smooth as could be. Please help me diagnose this noise, thank you in advance
Old Jan 3, 2023 | 02:50 PM
The location of a noise is disorienting from inside the car. When turning to the right, the driver's wheel gets more weight, so check the driver's side wheel for noise.
I suspect the wheel bearing is making the noise based on your description. The CV joint would be second on my list. Look at the CV joint boots for tears when inspection.
elvis1977
Nov 4, 2012 02:22 PM
holbert_charles1945
Jul 13, 2012 03:16 PM
thepacifist
Jul 12, 2010 09:45 PM
civand
Sep 18, 2008 11:14 PM
GTRider
Apr 25, 2008 08:00 PM
