Try the HVAC self-diagnostic test without a scanner.
I attached some pics of the procedure. This will help identify if the hvac control unit is detecting an issue in the system and may give you some direction.
Thanks PAhonda.
Not sure this will work for me as my car does not have the dual zone HVAC system. Just the basic with the temp **** to adjust,
This is tricky since you have only one blend door motor. You could remove the blend motor and manually move the air mix to see if something is not moving inside the heater unit properly.
It is possible you are dealing with 2 separate issues. A clogged heater core and low a/c freon.
If the air is being properly routed, you might be dealing with two issues. A clogged heater core and low R134a charge.
The next easiest step is to put pressure gauges on the a/c system to read the high and low pressures when the engine is running to check the a/c performance. Do not blindly add R134a to the system, because overpressurizing the system is dangerous and can turn into an expensive repair. At minimum, follow and inspect the a/c hoses and look for signs of leaks like oil/grime buildup at connections.
