2008 Honda Accord radio/climate display issues
Old Jul 29, 2018 | 03:15 PM
clinch9's Avatar
Exclamation 2008 Honda Accord radio/climate display issues
As of last night, my car radio/climate display has been working absolutely fine. I get into my car this morning and turn the ignition on and the far right 1/2 to 1/3rd radio/climate display is all jumbled. I put the radio into diagnostic mode to check the LCD display and it doesn't seem as if there are any problems. I've pulled the battery, cleaned posts/connectors, fuses checked, etc. Does anyone have any idea what might be causing this all the sudden and have any idea as to fixes?
Old Jul 29, 2018 | 03:43 PM
Is the problem just the display? Does the radio play music through the speakers? Heat and a/c controls work?
Old Jul 29, 2018 | 10:43 PM
clinch9's Avatar
As of right now, it’s just the display. I just can’t figure out if it’s an electrical problem or simply just a display problem. If it’s just display I won’t worry too much about it being a must fix right now. Just not sure why it happened overnight with no previous symptoms.
Old Jul 30, 2018 | 12:09 AM
It is likely a problem inside the stereo dealing with the display. You might want to search the web or youtube to see if anyone has run across this problem and possibly came up with a fix.
If it was an external wire or voltage problem, more items would not function.
Old Jul 30, 2018 | 09:52 AM
clinch9's Avatar
I’m hoping it’s just a display problem. Also hoped maybe someone around here had the same issue and knew something. I didn’t find much searching except people said the repair cost was anywhere from 300-500 dollars at the dealership.
Old Jul 8, 2024 | 07:45 AM
tanveer singh's Avatar
Default Did you find the fix. I am having same problem
Did you find the fix. I am having same problem [/QUOTE]
libby234
Jun 25, 2014 11:29 PM
GregSC
Jan 28, 2010 01:04 PM
europeanboy
Jan 1, 2007 07:51 PM
