2009 Driver Door Won't Open Consistently
Old May 4, 2014 | 10:24 PM
twistofmatt's Avatar
Default 2009 Driver Door Won't Open Consistently
On my 2009 Accord, when you unlock the doors, you can pull the handle either inside or outside multiple times before it will open, if at all. There have been instances where I've had to lock and unlock the doors multiple times to get it to open.
Is this the same problem that the TSB for the 2008?
Does performing the steps on this TSB require removing the inside door panel? The steps really just say remove the door latch, I assume that's inside and outside?
Thanks for any help.
Old May 6, 2014 | 09:19 PM
Not sure if that is the same issue or not.
Either way, yes to figure out what is going on the door panel has to come off.
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
jza240sx
Apr 30, 2013 04:14 PM
spinner
Apr 6, 2007 02:08 PM
jellero
Oct 11, 2006 06:10 PM
