2009 Recirculate light
Old Jul 9, 2012 | 10:17 AM
aldukeman's Avatar
Default 2009 Recirculate light
The recirculate function is not working on my 2009 Coupe LX-S.
The recirculate light will turn on if I start the car and Max A/C was on the last time I turned the car off. The light will then turn off if I push the recirculate button. When the light is off, the light will not turn on again when I push the button. In all instances, the recirculate function is not working.
Any ideas?
Old Jul 9, 2012 | 08:35 PM
I would check for codes in the HVAC system as a start? Are you sure it is the not just the light not working?
Old Jul 10, 2012 | 09:40 AM
aldukeman's Avatar
It's something more than just the light as the recirculate function doesn't work at all. The button is at least partially functioning as it will turn the light off.
How do I run the HVAC diagnosis on my 09?
Old Jul 10, 2012 | 11:09 AM
Depends on you unit. Do you have auto HVAC or manual.
See this thread, I posted both (post 9 and then post 15): https://www.hondaaccordforum.com/for...ant-fix-48478/
Old Jul 10, 2012 | 12:56 PM
aldukeman's Avatar
Thanks for your help! I ran the diagnostic and no code showed up, but everything is working now, so I guess it fixed itself. Now I just hope it stays fixed.
Old Jul 10, 2012 | 02:48 PM
I'm going to wish you luck
If the issue comes back, try the code check again.
Corvair
Aug 24, 2014 08:26 AM
HK500Pilot
Apr 24, 2013 07:31 PM
oziking
May 16, 2011 04:30 PM
hydroponik
Sep 9, 2009 06:09 PM
ptownoddy
Jul 29, 2009 01:21 PM
