2010 Accord V6 excessive oil consumption
Old May 24, 2011 | 06:47 PM
larf's Avatar
Default 2010 Accord V6 excessive oil consumption
Hi. I'm new to this Forum - have a 2010 EX-L V-6 with 29,000 miles. Uses a quart of oil in approx 1500 miles. Dealer says this isn't a problem unless a quart in 1000 miles or less. We are using the dealer recommended oil - a syn blend 5W-20. Have changed oil at the 30% life , and add oil in between.
This particular car has a 100,000 powertrain warranty. should i just relax and let the warranty address this or should I get more aggressive with Honda Corp?
Does anyone else have this issue or would share experience on how to solve it?
Old May 24, 2011 | 07:41 PM
I would be somewhat concerned and would insist on documenting this performance w/ Honda, so if things get worse you'll have a paper trail.
Suggest checking the PCV system for a blocked PCV hose or defective PCV valve.
rikee
Mar 10, 2015 09:24 PM
christmasinjuly
Nov 27, 2013 10:20 PM
iStagl
Nov 29, 2012 03:14 PM
mamtsberg
Aug 30, 2012 11:11 PM
axelrod
Dec 14, 2007 05:13 PM
