ERG Valve operation
Old May 22, 2011 | 08:01 PM
matt86's Avatar
Default ERG Valve operation
93 Accord 2.2 auto. The engine is stumbling/hesitating when you rev it up. I can see the EGR valve opening slightly, the problem goes away when you disconnect the vacuum hose.
Bad solenoid? weak EGR valve? Any suggestions?
Thanks
Old May 22, 2011 | 08:41 PM
Did you clean the EGR ports? You should also inspect the vacuum hoses going betwen the egr valve, the solenoid, and the vacuum control valve?
Old May 23, 2011 | 01:31 AM
matt86's Avatar
Thanks, I will clean the ports.
Old May 23, 2011 | 05:34 PM
If you are there, might as well pull the valve and clean it to be sure.
Old May 24, 2011 | 08:20 PM
matt86's Avatar
2 passages totally blocked, cleaning worked, hesitation gone.
Thnaks
The Feesher
Nov 16, 2013 09:08 AM
Swedevil
Aug 27, 2012 09:25 PM
olgirlkeepsrunnin
Jan 25, 2010 08:23 AM
linksys8
Apr 26, 2006 06:04 PM
Evlampius
May 17, 2005 10:51 PM
