2010 Honda Accord EXL V6
Old Jun 26, 2019 | 02:13 AM
Jonathan Valencia's Avatar
Default 2010 Honda Accord EXL V6
Hey guys
my 2010 Honda Accord EXL V6 with about 160k miles has a “check fuel cap” that keeps coming up on the dash. I replaced the cap, still get it on occasion when I start the car or mid drive. Anybody else experience this?
i have no check engine light on. Any assistance would be greatly appreciated
Old Jun 26, 2019 | 07:27 AM
Not sure why you don't get a CEL for that... You might want to go to a parts store & have them read any error codes that are stored but not displaying the CEL. The actual code number (something like P1234) is more useful than the guy's explanation of what's wrong.
What the sensors actually are measuring is to verify the fuel tank is airtight like it's supposed to be. A loose fuel cap is certainly the most likely, but there could be a number of other things.
Do you work on your own car? Comfortable getting it up on jackstands & crawling around underneath? Look for rubber hoses that are disconnected, or maybe dry & cracked. Rubber connections & hose clamps around the filler pipe? Anything like that. More likely up high on the tank (where you can't easily see it) because a leak down low would drip fuel or at least smell like fuel.
Old Jun 26, 2019 | 12:00 PM
The Toecutter's Avatar
Yup, I think I fixed my P1457 code while I was replacing my fuel and brake lines, as the tank vent line (steel) had rusted off right at the rubber hose (not the only rusty spot in that line either). That line got replaced while I was in there. So far no CEL light on. Just something to keep in mind IF they use salt on the roads in your state.
Old Jun 26, 2019 | 06:38 PM
After every fuel fill-up. just tightened the fuel cap at least 3 clicks.
The 3-clicks (at least) is part of published Honda info. to techs/advisers.
Jonathan Valencia
Mar 26, 2019 11:48 AM
jrasero
Feb 27, 2013 05:06 PM
Breadkeeper
Sep 16, 2012 10:51 AM
2010-V6-EXL
May 25, 2011 02:35 AM
jayz706
Apr 15, 2010 01:03 AM
