2011 Accord LX-P 4 DR, 4 CYL Spark Plugs Confusion
Old May 2, 2022 | 01:54 PM
notmyaccord's Avatar
Default 2011 Accord LX-P 4 DR, 4 CYL Spark Plugs Confusion
Howdy Gang:
Trying to determine which replacement spark plugs to purchase. Not certain if I have a PZEV emissions system or not?
A photo of the under-the-hood emissions label is attached to this post. Do I interpret this label to say my car has a ULEV emissions system and NOT a PZEV?
Thanks for any advice.
Old May 2, 2022 | 04:57 PM
1HG CP2 5 3 # 8 A 000000
Above is a generic vehicle ID number grouped by what they mean. The 3 spot is PZEV if that digit is a 3,4,7,or 8 for USA models. The 000000 serial number is a USA model if it is between 000000-800000. 800001 and above is a Canadian model. Hopefully this isn't confusing, but it looks like all USA models are PSEV.
The other item to identify PZEV vs ULEV is the engine number. K24Z2 - 100001 is a generic. K24Z2 is the engine type. If the 100001 section starts with 15 or higher, then it is a PZEV engine. The engine number should be on a metal plate on the engine near where the engine meets the transmission and should be on the side facing the front bumper. Hopefully it is also easy to spot.
Old May 2, 2022 | 05:27 PM
Originally Posted by PAhonda
1HG CP2 5 3 # 8 A 000000...
Thanks for that info, PAhonda. My VIN and engine number do decode to PZEV.
I was about to purchase the wrong plug.
Old May 4, 2022 | 12:09 PM
Default Was not a PVEZ after all!
Just to close out this question...
There was enough ambiguity in my mind since the emission label didn't state PZEV that I removed one plug and checked the mfg part number.
A Denso Iridium SXU22HCR11S was installed, which is for a ULEV emissions system, not a PZEV system.
This vehicle was manufactured in Marysville. These are definitely the original plugs installed at time of vehicle delivery. I am the only owner of the vehicle.
latour2323
Jul 25, 2016 08:05 PM
torrguy
Jul 18, 2011 06:01 AM
inthedump
Oct 27, 2009 05:48 PM
MisterBen
Sep 27, 2009 12:12 PM
saad180
Apr 2, 2006 01:39 PM
