2011 Accord power seat
Old Apr 18, 2022 | 12:42 PM
dadinnm's Avatar
Default 2011 Accord power seat
Drivers power seat slide motor suddenly got louder and after a few days, quit working. Should I assume it's the motor itself? Is it best to let the dealer fix it or is it an easy DIY?
Old Apr 18, 2022 | 01:20 PM
Most likely the motor. You should check the power and ground to the failed motor just to make sure you don't have an electrical issue. Also check that the gears aren't the issue. You should get a quote from the dealership to get an idea of cost, because they may opt to replace the whole seat. Price out just the motor.
I would personally DIY the repair, but skill level/confidence vary from person to person. At minimum, watch some youtube videos on how this is done on accords to get an idea of process, then you will determine if you want to attempt the repair.
Old Apr 18, 2022 | 02:13 PM
dadinnm's Avatar
Thanks, I called the dealer and am waiting for a call back with a quote for motor replacement.
SEADAVE
Apr 3, 2023 03:45 PM
Thorsteenster
Jun 29, 2016 02:09 AM
umtkyck
Jun 28, 2015 08:08 AM
mthomson
May 14, 2013 07:01 PM
rah140
Jul 4, 2012 06:17 PM
