2011 Honda Accord EX-L V6 P3400 code
Old Aug 17, 2017 | 09:53 PM
PKingFire's Avatar
Default 2011 Honda Accord EX-L V6 P3400 code
My check engine light came on, and when I got it diagnosed I got a P3400 code. I noticed that the last oil change I got the mechanic used the wrong oil. My plan to fix the vehicle is to replace the Rocker Arm Oil Control Solenoid and to change the oil to the correct 0w20. Is there anything else that I might be missing? Also if anyone has access to a Shop Service Repair Manual that would be a great help!
Old Aug 18, 2017 | 10:24 AM
How wrong was the oil at the last change? What oil was used?
Old Aug 18, 2017 | 11:39 AM
Looks like many possibilities for this code. See link:
https://www.yourmechanic.com/article...-jamahl-walker
If solenoid clicks when activated and has reasonable resistance (10-30 ohms?), then other causes should be investigated.
Old Aug 18, 2017 | 01:22 PM
PKingFire's Avatar
Default @JimBlake
they used 5w20, is that enough of a difference to cause an issue over time?
Old Aug 18, 2017 | 01:29 PM
PKingFire's Avatar
Default @TexasHonda
Thanks for the link, I've already ordered a replacement solenoid and am changing that this upcoming Sunday. Does anyone have any sources for getting a PDF or free version of the Service Shop Repair Manaual to aid me? I've found a few videos, but wouldn't mind the actual document
Old Aug 18, 2017 | 01:46 PM
5w-20 vs 0w-20 shouldn't have anything to do with this. Only difference would be really cold starts, wintertime in northern states. Waste of time chasing oil as the cause of this trouble.
Old Aug 18, 2017 | 01:57 PM
PKingFire's Avatar
Default @JimBlake
Thanks, appreciate the imput. Hopefully it's the solenoid then, which seems like a pretty simple repair. I also plan to clean the oil lines of any debris that may be affecting the oil
pressure itself. Since my car won't switch back into ECO mode then I'm hoping I've pinpointed the issue
Old Aug 18, 2017 | 05:06 PM
There are two separate Honda service bulletins regarding this trouble code.
First check if your oil level is low.
Compare your VIN with the VIN range listed for the 2011 Accords in the TSB No. 11-033. -- If the engine oil is low, a PGM-FI software update (if applicable) may help.
If the engine oil is not low and your car is not within the listed VIN range in TSB 11-033, then see TSB 13-031. The cause may be due to the front and/or rear rocker arm oil pressure switch failing intermittently.
File Type: pdf
File Type: pdf
mursheddy
May 7, 2012 12:47 PM
Khai Son
Mar 14, 2012 11:32 PM
sap67
Aug 2, 2011 07:48 PM
Rtherres
Jan 30, 2011 04:58 PM
madsteez
Jan 18, 2009 07:43 PM
