2011 Power Steering Pump
Old Feb 27, 2016 | 11:33 AM
RahulP's Avatar
Default 2011 Power Steering Pump
Hello all, I am new to the community and appreciate all of your valuable feedback. I own a 2011 EX-L 4-Cyl with about 90k miles and have been experiencing a whining noise lately, mostly during turns. I was at the dealership for an oil change and asked them to diagnose it, and they returned saying I need a new power steering pump and it will cost $525. There was no mention of a leak or anything, they just simply said its going bad and will fail soon. I feel like its too early to be experiencing this issue, but can anybody corroborate this sounding reasonable? I have been going to this "award winning" dealer since I bought the car from them, but I must say there have been times when I did not trust the recommendations from the service department and felt they were trying to sell things I don't need. Perhaps there is an easier solution to try first?
Old Feb 27, 2016 | 11:53 AM
You stated no leaks; but, is the power steering level okay?
Do you see bubbles in the fluid? Can be air in the system.
You can try a relatively inexpensive and easy fix, similar to this service bulletin by replacing the inlet joint o-ring to see if it makes a difference.
File Type: pdf
Old Mar 1, 2016 | 08:21 AM
Dr. Drivability's Avatar
I call B.S. on a new P.S. pump, put an O-ring in at the pump on the return line and be done with it. 3 bucks vs. 525....HA!
Old Mar 1, 2016 | 08:34 AM
And if it turns out the O-ring didn't fix it, and you actually need a new pump, you haven't hurt anything by trying the O-ring first.
WhyNotFab
Sep 30, 2006 05:25 AM
Rizzie
Aug 21, 2006 03:26 AM
BDN54
Mar 9, 2006 02:34 PM
WS6M21
Dec 4, 2005 11:37 PM
WS6M21
Nov 9, 2005 01:50 AM
