2012 Accord Radiator Fan not turning on
Old Aug 19, 2017 | 06:49 PM
derekf's Avatar
Default 2012 Accord Radiator Fan not turning on
Hi, 2012 Accord, base LX, automatic. 105k miles.
I overheated today in a fast-food drive-thru; had probably been idling for 20 minutes in hundred degree temps before I realized just how hot the engine was getting and shut it off.
Once they gave me my food, I got straight on the highway and as expected, the temps dropped back to the expected range.
When I got home, I popped the hood and checked - the driver's side fan is running (with AC on), the passenger side is not.
Read lots of posts; many were different generations of Honda or not even Honda cars so I am a little lost on where to start troubleshooting.
Assuming the two fans use different fuses and relays, as well as different signals for on/off - which is the fuse/relay this one uses? Is the sensor that controls this fan in the thermostat or was that a different generation?
Old Aug 19, 2017 | 08:00 PM
The passenger side motor is the A/C condenser fan motor. First check to see if under-hood Fuse No. 5 (20A) is blown. If that fuse is not blown, disconnect the fan motor connector and apply direct 12 volt to the motor's red wire, and ground (-) to the motor's black wire to test the motor.
Both fans should run at the same time with A/C on or if coolant temperature is above 206 degrees F.
When the car has sufficiently cooled, also check and top off the radiator and reservoir coolant if needed.
Old Aug 2, 2022 | 11:22 AM
cocogrove's Avatar
Did anyone solve this issue? I am having the same one
Jenny Jordan
Dec 22, 2023 11:04 AM
Novaknowledgenow
Jun 2, 2013 05:48 PM
poorman212
Mar 7, 2012 08:27 PM
biggamejojo
Jul 22, 2011 10:38 AM
muibu
Jan 25, 2007 05:47 PM
