Sponsored by:
Sponsored by:
2012 Honda Accord taillight not working, brake lights are
Old 08-19-2018, 06:59 AM
Giles Siadous's Avatar
Default 2012 Honda Accord taillight not working, brake lights are
First post here. So my left taillight won't work but the brake light is working (same light bulb) everything else on the car works and has no other issues. Anyone know what the problem could be?
Old 08-19-2018, 11:34 AM
Have you check the bulb? The bulb has two filaments; one for the brake light and another for the taillight. The taillight filament may be broken.
Old 08-19-2018, 01:15 PM
Yeah I changed the bulb about a week ago, is there a certain way to check the filament?
Old 08-19-2018, 01:29 PM
Visually check if the two filaments are okay. You can also swap bulbs from the different side or try another bulb.
Otherwise, if you have a voltmeter, test for power on the Red wire at the connector with the headlight switch turned on.
Old 08-20-2018, 09:20 AM
Since it didn't come back with a new bulb, another possibility is the contacts down inside the socket.
After checking the wire like redbull said, if that's getting power you can also look for screwed-up contacts inside the socket (bent? corroded?).
Renee Townsend
02-17-2015 10:40 AM
csh217
04-30-2013 09:03 PM
96cord
08-02-2012 12:10 AM
crispin
05-15-2012 09:06 AM
Quick Reply: 2012 Honda Accord taillight not working, brake lights are
