2012 Honda Accord taillight not working, brake lights are
Old Aug 19, 2018 | 06:59 AM
Giles Siadous's Avatar
Default 2012 Honda Accord taillight not working, brake lights are
First post here. So my left taillight won't work but the brake light is working (same light bulb) everything else on the car works and has no other issues. Anyone know what the problem could be?
Old Aug 19, 2018 | 11:34 AM
Have you check the bulb? The bulb has two filaments; one for the brake light and another for the taillight. The taillight filament may be broken.
Old Aug 19, 2018 | 01:15 PM
Yeah I changed the bulb about a week ago, is there a certain way to check the filament?
Old Aug 19, 2018 | 01:29 PM
Visually check if the two filaments are okay. You can also swap bulbs from the different side or try another bulb.
Otherwise, if you have a voltmeter, test for power on the Red wire at the connector with the headlight switch turned on.
Old Aug 20, 2018 | 09:20 AM
Since it didn't come back with a new bulb, another possibility is the contacts down inside the socket.
After checking the wire like redbull said, if that's getting power you can also look for screwed-up contacts inside the socket (bent? corroded?).
Renee Townsend
Feb 17, 2015 10:40 AM
csh217
Apr 30, 2013 09:03 PM
96cord
Aug 2, 2012 12:10 AM
crispin
May 15, 2012 09:06 AM
