2012 Interior Lights
Old Apr 2, 2025 | 02:07 PM
Packy2's Avatar
Red face 2012 Interior Lights
The driver side interior overhead light does not come on when I open the doors. The passenger side works fine. I have replaced the small push buton switches swithces on both sides, but no change. Checked all interior light fuses and they are fine.. I push the driver side off/on switch and the light works. What am I missing? Yes I have moved the switch from door to off na back to door.
Driver side light does not work when doors open
Old Apr 3, 2025 | 12:33 AM
Does the driver's door have a courtesy light when you open it and does it work properly?
If you have a volt meter or test light, remove and unplug the door switch, then test for 12V on the wire. Use a bare metal like where the seat bolts to the floor as the ground. If the swtich has two wires (not familiar with the 2012 setup), then test the non-black wire (brown?) for voltage.
LDB415
Jun 13, 2018 11:36 AM
oldbeek
Sep 11, 2013 07:23 PM
dbeltran315
Apr 30, 2013 09:13 PM
N1Accord
Mar 24, 2011 11:27 AM
scottyd101
Jan 3, 2009 10:49 AM
