2014 v6 EXL ABS FWC LCW TYRE ON :(
Old Nov 7, 2017 | 10:50 PM
Moto Sportsgr's Avatar
Unhappy 2014 v6 EXL ABS FWC LCW TYRE ON :(
Hi there
I just replace the rear bearing(complete hub) with a after market from autoparts
start the car and i get ABS, FWC, LCW,TYRE LIGHTS ON (TYRE NOT RESET from dashport,lcw not work)
i replace the sensor cable cose i thow i hard the old one,lights off after sort ride everything works good
but after 50 miles lights on...same problem
*I notes that abs was very sensitive after add the new sensor
Anyone have any idiea what is the problem...
Old Nov 9, 2017 | 04:58 PM
I'm going to move this over to General Tech where more people will probably see it. The "new member" area is mostly for welcome & introductions.
Old Nov 9, 2017 | 09:46 PM
Did you have this problem before you replaced the bearing/hub assembly?
Cardsallday13
Jan 4, 2016 02:09 PM
Smokey
Nov 24, 2006 01:13 PM
unco
Jun 17, 2006 05:22 PM
Gspot
Mar 17, 2006 10:18 AM
tricky
Jan 24, 2006 11:51 AM
