2015 Accord rear bearing replaced but ...
Old Feb 13, 2018 | 11:40 PM
Sebag75's Avatar
Unhappy 2015 Accord rear bearing replaced but ...
... on my dashboard I have 4 lights on after replacing rear passenger side bearing. ABS light is on, Flat tire blinks then goes steady, traction control light is on and steering issue light is coming on after few second of engine start. Any idea what might be wrong? I replaced bearing twice and 2nd time I also replaced the sensor. I reset all the codes/lights with a computer but all goes back after driving the car. Disconnected battery for about about 4 min but it didn’t help either. Can someone help me please?
Old Feb 14, 2018 | 04:38 AM
Seanjordan20's Avatar
Are you using the correct part for your car? And you did only replace the bearing and not assembly, correct?
Old Feb 14, 2018 | 04:44 AM
I assume you replaced the assembly. What brand is the part? Make sure your sensor is completely clean and plugged in all the way. It should of been an easy swap so something is missing.
Old Feb 14, 2018 | 09:23 AM
Did you also calibrate the TPMS system afterward?
Your Accord comes with an indirect TPMS that doesn’t use tire pressure sensors mounted inside the tires. Instead, it uses the existing VSA wheel speed sensors to monitor and compare tire characteristics while driving.
Instructions for TPMS calibration is part of the owner’s manual and available online.
Old Feb 14, 2018 | 12:53 PM
Sebag75's Avatar
Default 2015 Accord rear bearing replaced but ...
I replaced bearing with hub assembly.
Old Feb 14, 2018 | 12:55 PM
Sebag75's Avatar
Tha rear bearing hub assembly was an aftermarket part. I will have to check part # but the store owner said it is good for my 2015 Accord.
Old Feb 14, 2018 | 01:02 PM
Sebag75's Avatar
I was trying to do the calibration but I was getting message that it failed. Should I do it with just ignition ON? Keep in mind that flat tire light blinks for like 20-30 seconds then it’s steady beside other lights on my dashboard like ABS, Traction control and steering wheel. All of those lights are ON on my dashboard
Old Feb 14, 2018 | 02:34 PM
Something is not plugged back in right. I would look at the area again.
Old Feb 14, 2018 | 06:46 PM
Get the trouble code(s) read and post the actual code number(s). Many auto parts store will read the codes for free. It has to be a OBD reader/scanner capable of reading Honda ABS trouble codes.
Old Feb 14, 2018 | 07:32 PM
Having the code will help you pinpoint the issue. Being that you know the work you did caused the issue the code will help little. There are 4 things that will cause your issue ( wrong part/incorrectly installed , unplugged/broken sensor or recalibration). If you get the code do post it.
