2015 Accord rear bearing replaced but ...
Old Feb 15, 2018 | 02:42 PM
The Toecutter's Avatar
Originally Posted by Seanjordan20
Having the code will help you pinpoint the issue. Being that you know the work you did caused the issue the code will help little. There are 4 things that will cause your issue ( wrong part/incorrectly installed , unplugged/broken sensor or recalibration). If you get the code do post it.
Or take it to your local Honda dealer and have them read the codes. They'll pin point what the fault is. We did that with my wife's car, and they had no problem reading which wheel was kicking the ABS code. She told the tech that she just wanted the code read, and that I would fix it. Turned out to be a bad sensor in the RR wheel.
Old Feb 15, 2018 | 03:00 PM
Sebag75's Avatar
My mechanic has the computer to read the codes. First it said “Sensor installation failed” or something similar. We put New bearing and then he cleared the code. It was good for maybe a minute and all the lights on my dashboard came back. I spoke to another mechanic and he said that I need original bearing not aftermarket since original has some magnetic piece which is working with sensor. I am buying original bearing from Honda and will let you know if it resolved my issues. Thank you everyone for your tips. I really appreciate it. I will keep you posted. Thanks
Old Feb 15, 2018 | 06:20 PM
The magnetic encoder ring is incorporated as part of the wheel bearing. The encoder (brown color) has to be installed toward the inside of the knuckle.
Old Feb 17, 2018 | 03:45 PM
Sebag75's Avatar
So yesterday we installed original bearing from Honda and when I started my car all 4 lights were still ON. But then I drove my car and all disappeared so my issue was fixed! Lesson learned- no more aftermarket parts ever! Thank you all for your input.
Old Feb 17, 2018 | 04:37 PM
Seanjordan20's Avatar
Good to hear it. The newer Hondas a sensitive like that with many parts
gary85_
May 27, 2014 05:25 PM
joenintiesc
Apr 14, 2013 07:29 AM
thadjons2007
Dec 8, 2010 07:10 PM
dougs honda
Apr 25, 2010 07:55 PM
oma93
Feb 6, 2008 12:43 AM
