2016 Accord Touring Coupe front LEDs out
Old Oct 4, 2019 | 11:41 AM
Probizjudi's Avatar
Default 2016 Accord Touring Coupe front LEDs out
Just discovered the LED lights are out on the front right side - daytime lights. I also just learned this has been an issue with the LED strips.
Before I spend an arm & a leg what would is the best way to replace these DIY or take it somewhere? I heard of dealers charging astronomical prices so want to do this as economical as possible. Also can the LED strip be replaced and does it need to be an authentic Honda part?
Thanks for an help you can send me way! Appreciate it!
Old Oct 4, 2019 | 08:43 PM
There was a DRL LEDs warranty extension to 10 years with unlimited mileage from the original date of purchase. The whole headlight is replaced. Your Touring model with LED headlights and DRL LEDs is even more expensive than other trim levels.
Honda TSB 19-042
Old Oct 5, 2019 | 07:47 PM
dmaynard's Avatar
Default Same happened to me
Headlight replaced no problem. It appears to be a passenger side issue
Old Oct 6, 2019 | 02:18 PM
Probizjudi's Avatar
Thanks for your response. Mine too is passenger side. Was the replacement covered under the warranty? Did u have it done at a Honda dealer or what? Thanks again!
Old Oct 6, 2019 | 03:56 PM
EXV6NIGHTHAWK's Avatar
I've already had both headlights replaced under the extended warranty. Yes, if you want Honda to cover it, bring it to a dealership.
Old Oct 12, 2019 | 05:35 PM
Probizjudi's Avatar
Thanks for all your input. Car goes to the Honda dealer Monday and they will replace both headlights! Yay! So glad I found out about the warranty on here! You guys are the best!!
Rx7380
Jun 1, 2016 07:34 PM
Mattc941
Mar 17, 2016 07:08 AM
accordtouringnightmare
Feb 20, 2016 11:52 PM
TabbyP
Jan 27, 2016 09:40 AM
iceblitzed
Sep 18, 2014 06:12 AM
