2017 Honda Accord Hybrid Front Grille Replacement
Old Dec 29, 2020 | 09:11 PM
rqualls's Avatar
Default 2017 Honda Accord Hybrid Front Grille Replacement
Hello
I have a 2017 Honda Accord 4 door sedan (Hybrid) and need to replace the Grille. The OEM appears to be in 6-7 different pieces and expensive. I have seen some other options, but some say they do not fit the hybrid. I am wondering what the difference would be between the Hybrid and Non-Hybrid. The options are either after-market grilles or used grilles - but need to determine if the Hybrid is specific and some of these other options really won't fit. Anyone know?
Thanks,
RQ
Old Dec 29, 2020 | 09:53 PM
Are you referring to the upper grille or the lower bumper grille?
The Hybrid grille is different than non-Hybrid.
For example, the Hybrid lower bumper grille mesh is separate from the outer grille. On non-hybrid, the mesh is not a separate piece.
The Hybrid lower grille pieces doesn't all need to be replaced if they are not all broken. There is molding piece too.
Old Dec 29, 2020 | 10:05 PM
rqualls's Avatar
I am referring to the upper grille - there is a base and 3 different chrome trim peices that attach to it, along with the Emblem (which mine is still ok)... I see a Sport Grille (one piece) 08F21-T2F-100 but not sure it will fit even though it says it does on one parts site - but it also says it fits the non-hydrid, so a little skeptical...
the parts I think I will need are 71121-T3W-J52, 71124-T3W-J51, 71123-T3W-J51 AND 71104-T3W-J51 so adding all those up is over $600 worth of plastic...
Thanks,
RQ
Old Dec 30, 2020 | 12:58 PM
I'd look for used parts. Ebay is an option. Also car-part.com is a site that searches junkyards that list parts on the site by distance or price. I'm not sure if car-part.com will list the grill as an option, but you should be able to locate yards with 2017 hybrids in your area.
rice81
Feb 27, 2014 07:33 AM
jpulone
May 28, 2013 07:06 PM
Accord Owner
May 24, 2010 07:02 PM
scottisart
Nov 1, 2009 11:25 PM
R_ACE1
Jun 12, 2009 12:15 AM
