205-60-R16 to 205-55-R16? Can I use? They're FREE!!!
Old Oct 28, 2012 | 02:04 PM
Jeff247's Avatar
Default 205-60-R16 to 205-55-R16? Can I use? They're FREE!!!
Long story short, my sister has 4 brand new 205-55-R16 she doesn't want but my 2003 Honda Accord EX takes 205-60-R16. Can I use the 55's? Thank you.
Old Oct 28, 2012 | 08:53 PM
Yeah, but your speedometer & odometer will read a bit high. They're 10mm shorter on the radius, so your car will sit 10mm closer to the ground. For most people that won't matter. If yours is lowered much, you might have to worry about that.
You also have 10mm less "cushion" for potholes, so it might be just a bit easier to bend a rim.
Old Oct 29, 2012 | 05:56 AM
Jeff247's Avatar
Default I'm going to do it!
Thank you for your help.
Old Oct 31, 2012 | 09:38 AM
Jeff247's Avatar
Default How about air pressure?
I checked air pressure and the installer put 36 lbs in each! I let enough out to get to 32 front and 30 in back as called for on door panel. But these are 205-55-16 and not the manufacturers recommended 205-60-16. They feel fine, but should I make an adjustment for the 55's?
I have always run Michelins, but these 55's are Bridgestones
Thank you.
Old Oct 31, 2012 | 10:04 AM
Dr. Drivability's Avatar
you should always adjust to what the door sticker says, not what the tire says...i'm betting the max press for those tires are around 44-51 psi. the recommended pressures are the best for ride and economy.
MessAround
Aug 30, 2017 10:05 AM
darsunt
Mar 26, 2013 08:41 PM
Hondagirly
Jan 11, 2013 04:08 PM
matt2005
Sep 29, 2012 07:09 AM
Davewave
Dec 3, 2008 08:49 AM
