3 Problems replacing door actuator
Old Dec 4, 2011 | 11:17 AM
RandyL's Avatar
Default 3 Problems replacing door actuator
Hi,
I encountered 3 problems while trying to replace my door actuator. 2 of them I require help with.
1) A metal piece fell out while trying to remove the old actuator. I have no idea what it is for or where to install it back. Can someone please help me identify it and where/how to reinstall it?
2) I accidentally took out some bolts and when I tried to reinstall them, the holes no longer line up. Can someone please give me some tips or explain how I can get the holes to line up so that I can reinstall the bolts?
3) No one can help me with this problem. I was stupid and went into this task without doing my research first and starting taking all screws and bolts that I thought might help me replace the actuator easier.
Any help would be greatly appreciated.
Thanks!
Randy
Attached Thumbnails 3 Problems replacing door actuator-2img_1478.jpg   3 Problems replacing door actuator-2img_1479.jpg   3 Problems replacing door actuator-window-bolts-misaligned2.jpg
Old Dec 4, 2011 | 11:46 AM
As far as the bolts, they are for the regulator. Suggest moveing the glass around to get it properly set, the reg bolts should then line up.....
The plate looks like a "guide"/protector for the door locks.
Might look for some u tube videos on replacing the regualtor and or the actuator and see if they help.
Attached Thumbnails 3 Problems replacing door actuator-99-window-reg.jpg   3 Problems replacing door actuator-99-door-locks.jpg
Old Dec 4, 2011 | 12:22 PM
accordhybridowner's Avatar
Is it possible to take the siding off the other door, which is currently intact, to see how the metal piece is installed?
Old Dec 5, 2011 | 01:35 AM
RandyL's Avatar
Hi,
Yes, you are corect. The metal part goes on the back of the actuator. Is it possible to install the actuator with the metal backing already installed? I screwed the actuator to the metal guide but am having a lot of difficulty getting the actuator connected.
I will try looking through You tube.
Thanks!
Randy
Doublel
Mar 11, 2013 07:57 AM
justvisiting
Jul 6, 2012 12:28 AM
tbopha
May 7, 2006 03:03 PM
BILL
Jan 23, 2006 05:49 PM
MichaelEXL
Oct 22, 2005 07:13 PM
