4th gear slips (revs to5500 then engages)
Old Dec 10, 2013 | 01:23 PM
donwon's Avatar
Default 4th gear slips (revs to5500 then engages)
Just put in used tranny shifts great 123 sometimes 4th slips then catches .put lucas trany slip in when I put trans in.no codes or lights ? 94 accord
Old Dec 11, 2013 | 07:49 AM
New clutch with the trans?
(or is it an automatic??)
Old Dec 11, 2013 | 09:51 PM
Rilex's Avatar
check for malfunction solenoids
Old Dec 12, 2013 | 08:18 AM
donwon's Avatar
It is automatic and only does it when its cold.after you drive for awhile its fine.I have put lucas automatic trans slip in and no help.I do have old trans and solenoids which one can I try ?
Old Dec 12, 2013 | 10:04 AM
Check for trans codes by shorting service check connector under glove box and reading flashes of D4 light.
Download 94-97 Accord manual from Online Manuals post in DIY forum for key to codes.
Also if no TCM codes, then check hydraulic symptoms chart in shop manual for clues to rpm flare w/ 3-4 shift.
phantom699
Apr 7, 2015 11:17 PM
gnshirhall
Oct 19, 2013 08:58 AM
vral81
Mar 6, 2012 01:28 PM
Ninjaboi112
Sep 6, 2010 08:15 AM
donaldghawks
Aug 26, 2009 05:04 AM
